bonedaddy
Quick question, It I had to use my torque wrench to break the lugs loose on a tire does that means I messed up the insides? Will it still give accurate readings? I use it all the time so I want to make sure I can trust the wrench... I wasn;t really thinking about it when I used it, I just needed something longer than my 4-way and it was right within reach... after I was thinking about it. I know it is reversible, but not sure if you are suppose to use it to loosen... outside of adjusting and using I rerally do not know much about the inner workings - I just tighten until it clicks...
- Donnie
- Donnie
