Torque specs
JeepinLife
Does anyone know the torque specs for the rear drive shaft yoke nuts ( forward and aft yoke) 07 rubi
It will depend on what your rotational torque is if you do it correctly. I believe some people don't check that because it requires an in-lbs torque wrench and torque to 160ft lbs and call it good. there is a write up on d.s. install that will tell you the torque specs. But it's 160 ft lbs for axle yoke and 130ft lbs for t case flange.
Thanks, got her done.
