bhaner
With 40" tires should my toe-in settings be different than the factory spec?
I currently have it set at 1/16" toe in. Just wondering if it should be different.
I have set my caster anywhere from 5° to 10° and it doesn't seem to change how it drives much.
It is currently set to 7° as directed in the PSC instructions.
The problem is I have a wonder going down the road. I am constantly over correcting. I would go as far as to call the steering "twitchy". You want to turn slightly left... You turn slightly left... But it turns a ton left... So you turn right to correct... Then left to correct that. And so on.
I am not sure if it is an alignment issue or something to do with the PSC assist/gear box.
