The BAD Influence
While trying to figure out the wobble on our Jeep, we had several shops look at and try to diagnose the issue. One buddy who has an alignment shop noticed the toe was a little too far out, so we adjusted them in a bit.
I finally had time to install the Crown ball joints, and knew immediately that had fixed the wobble. However, now it seems to want to wonder, or follow every little imperfection in the road.
Since it's obvious we adjusted the toe in, based on bad ball joints, and all other tie rods are tight, would this slight toe in be causing what I'm describing.
Thanks
Thanks
