Hey Guys,
Which is the best 4" lift kit for the tj?
@wayoflife
Mine is 00, with 4" long arm kit do I need a Slip Yoke Eliminator??
Why long arm? Is the zone 4 1/4" any good? Looks to be all bolt on.
It'll help correct your suspension geometry and offer a better ride. If your Jeep is a daily driver, this can be nice to have. I am not a fan of Zone.
What is your opinion about rough country's long arm kit??
Ok, i didnt know it would not correct the geometry. I know lifting anything messes with the steering geo and the pinion angle, i thought they would have the parts to correct that with the kit.
So, just to conclude on this.
If I install adjustable control arms:
A) will it gonna ride better?
B) it still gonna need a sye?
C) is the drop case spacers mandatory?
E) will the pinion angle gonna change?
After the installation of the control arms do I have to install an adjustable trackbar also?
i have rough country long arms, they work. Are they the best out there? No. but if your on a budget like me then they will do just fine. no welding is involved, just bolt everything on. it will ride alot better once you put them on. i would suggest you doing a SYE so that you dont have any drive line vibes. with the rough country it will drop the case about an inch. the arms come with all the measurements to correct the pinion angle, i would go ahead and install adjustable track arm in the front, the kit will have what you need for the rear. Hope this helps.
