Hi guys,
This is my first post so I'll try to be as detailed as I can. I bought a 1999 TJ Wrangler back in January that I've done a lot of work/rebuilding to. It's pretty much ready for the road other than needing front upper/lower ball joints and a parking brake, but I can't figure out the parking brake for the life of me. I've done a bunch of research online and have found the EB4- M.O.R.E Emergency Brake Cable for the 8.8, but this appears to just be a conversion cable and I need the entire cable from where the OEM TJ cable ends (approximately from under the rear seat) all the way to the rear axle, as the 8.8 does not currently have any parking brake cables attached to it.
If anyone has run into this before, any information would be helpful.
Thanks a ton!
Will
Thanks a ton!
Will
