Gadget Caught the Bug Mar 2, 2015 #1 I know you can make the JK show you the failure code, can you do this with the TJ also, and if so how?
cbmatt66 New member Mar 2, 2015 #2 For my 06 LJ by turning the key on and off 3-4 times within a 5 second time frame it would show the error codes on the odometer display.
wayoflife Administrator Staff member Mar 2, 2015 #3 Yup, depending on the year of the TJ, the key trick will do the job. Any OBDII reader will give you codes too.
Thatredjeep New member Mar 2, 2015 #5 Joker151 said: What years won't work? Mines a 99. Click to expand... Everything 95 and newer has OBDll so you should be good.
Gadget Caught the Bug Mar 2, 2015 #6 Tried the method written up for the JK, didn't work, is it different for the TJ?
