What's your backspacing on your wheels?So put on some aftermarket liners in the front and they seem to be rubbing when I do a full turn. It rubs in the back part of the liner. My tires are 37 13.5. Anyone else have issues?
Sent from my SM-G965U using Tapatalk
What liners? I am installing the Evos at this moment and running 37x12.5x17 on 3.5 BS and to my eye there is a ton of room.So put on some aftermarket liners in the front and they seem to be rubbing when I do a full turn. It rubs in the back part of the liner. My tires are 37 13.5. Anyone else have issues?
Local fabricator. Here is a pic of a full turn. I'm assuming I installed them correctlyWhat liners? I am installing the Evos at this moment and running 37x12.5x17 on 3.5 BS and to my eye there is a ton of room.
Sent from my SM-G975U using WAYALIFE mobile app
It attaches at the top with the stock fasteners. Then has 4 places around the outside that you have to drill and bolt onIs the bottom of the liner hanging out too far away from the jeep? How does the bottom of the liner attach to the Jeep?
Yep I installed it wrong. I drilled in the wrong spot. I moved it and was able to push it much farther into the well. It's good now. ThanksIs the bottom of the liner hanging out too far away from the jeep? How does the bottom of the liner attach to the Jeep?
My 37x13.5 Mud Grapplers rub at full stuff and full lock turn. Nothing serious, just rubs the paint off my CC liners. I also have 3.5 bs and 1.5 inch spacers.
Sent from my iPhone using Tapatalk Pro
