Looking at getting new tires in the spring and would like a lift also. I was thinking 35 or 37 with a 3inch lift. My JKU has 4.10 ratio. What's the biggest I can or should go for a daily driver plus off road. Options on Tire size and lift to go along?
Haven't really set an amount at all. It's my first jeep so I really don't want the best on it. It's just trial and error for now until i learn and get the hang of things then I'll get a new jeep with the nicer mods. It's kinda my prototype. Maybe do under $600 for the lift if possible. I really like the looks of 37s. I'm in Michigan so we don't have a lot of rocks up here mostly old logging trails so maybe 35s would be the best bet.
I'm running a 4" rough country lift. (500 bucks) and I really like it it gets the job done for sure.
Just because you can lift your Jeep 4" and for only $500 doesn't mean that it's a good idea or that you should especially if you use your Jeep more than for just flexing it out on the trail. At that height, you really need to address things like your front drive shaft and rear as well if you have a 2-door. You will want new longer shocks, extended brake lines, longer sway bar links for the rear and front as well if you have a Rubicon. Of course, 4" is crazy tall for as set of 35's and if you choose to run 37's, regearing is highly recommended as well. This is to say nothing about adjustable control arms to set caster and pinion angles or track bars to recenter your axle or even better, drag link flip/track bar relocation brackets.
Just trying to put things into perspective.
Why can't you wheel what you have? We wheeled our Jeep nearly stock for a year while we found our build direction and it was a blast. If I only had $600 to work with I would spend it on recovery gear and some armor. Oil pan, and if you have an auto the transmission for sure. The cross-member is nice IMO as well.
If you are doing this mostly for looks. As mentioned throw some spacers on it and be done.
As Eddie and others have noted, a budget boost is a great option. Pair that with some stock Rubi springs and shocks (can be had used for pretty cheap/free if Panda has em. :thumb: ) and you are set. As for wheels/tires, you can look for some used 35s. Or keep eyes open for a set of newer Rubi take offs. With this set up, you can definitely get out and have some fun and still have a very nice daily driver.
Not to argue your point but it's always easier to wheel a stock Rubi than a stock sport or Sahara. I agree with using the $$ on recovery gear first though. :yup:
I wheeled the piss out of my stock sport!
