Hi all I recently mounted some Open Country A/T II 35/12.50R17 on the stock wheels. I was wonder what tire pressure I should run while on the trial while crawling and how low I can safely go in the sand without worrying about popping a bead.
Thanks for the info in advance.
Ok I get it... Air down..more traction etc.
SE Arizona mix from good trail... to sand washes... to light rock crawling all in a 2 to three hour period... I have not aired down yet with no problems getting stuck (maybe not challenging myself enough yet :thinking
should I be running lower pressures all the time while off pavement or only when I am off trails/fire roads?
the compressor I carry (in the event I need to air down) will take a long time to inflate from 15psi back to normal. Once I am stuck its too late right?
I have even gone 80MPH on a 'fire road' while aired down.
I have aired down on every trail I have been on even with stock tires. It is worth it for the better traction. I have even gone 80MPH on a 'fire road' while aired down.
Ballsy!
Sent from a migrant connectivity device
