I am not sure what Eddie has, but here is what I did.
First pic is what I have used for years that came with my Power Tank.
It works good, but I was tired of holding the handle, plus the hose was not long enough to stand, and my knees don't like to crouch down for long.
Second pic is what I made up. It is mostly Harbor Freight with a good gauge from Amazon. I did several versions of this before I got to what I am mostly happy with. All told, I have just under $30 in it.
The first one I made had a longer hose, and it was too long. I also had a swivel fitting, until I found out how small the ID was and how much flow it restricted.
The current version has a 3' hose, clip on straight air chuck, and two ball valves on a tee. I tried it with just one valve, but the gauge was not happy with the 200 psi from the Power Tank.
This set up will rest on the tire, and stay there, while you stand and check air. You have to close the supply and open the gauge valve to check, but that is super easy to do.
I used a quality 0-60 psi gauge, so it is easy to read. My first one I used a liquid filled gauge. I don't recommend that, it leaks the liquid out. I think I blew a seal when I used it with the Power Tank, before I added the second valve.
In the close up, you can see how it goes together.
Bonus is it also works as a handy deflater.
