MericaMade
I just got done installing the EVO skins and tire carrier and wanted to know from you guys running them if your carrier rattles a lot? The Genright tire carrier I removed never made a sound or rattled at all but I think that was also due to the rubber isolater at the hinge pins vs. johnny joints or simply install error on my part.
Right now, I actually have to push down on the EVO carrier to close it. Not much pressure but it will not close unless I put a little down pressure on it. Should the Johnny joints be floating in between the drive hinges or should I allow some weight to sit on it? I also miss aligned the holes slightly to give the pins a tighter fit but can still hear rattling on ever single bump.
Also, any one have a cleaver way to run the wiring from inside jeep to license plate?
