Has anyone replaced the entire fuse box due to electrical problems???
Yup. The TIPM can go bad and it costs quite a bit to replace it.
Hey Eddie. Would an issue with that throw a check engine light??
A bad fuel cap will also cause the check engine light come on
Having issues with no check engine light. Hesitations while driving with no codes and already installed new fuel pump and new throttle body with no change
When was the last time you changed or checked your plugs?
may also have a failed or failing coil
Changed plugs 20 k miles ago. Coils are original and not throwing a check engine light
Only happens after I’ve been driving for 40 min or longer
