Dune Crawler
1st issue-Been dealing with a faint shimmy/wandering on the jeep I believe it's from the toe being out to far (notice in one of my pictures that the tires faced outward significantly)
the issue I'm having is the tie rod jam nut won't move for the life of me. I've put a plumbers wrench to it, a little heat to try to soften it, WD40. Is it safe to assume it's rusted to the point of no return and just need to get a new one? Or is it possibly that I need to pull it off the jeep to release some tension then try?
2nd issue-steering wheel is somewhat loose (not as tight as when I bought it) I put a 2.5in lift on it, but with back seats out, cutting of the frame,etc I'm netting 2.78 and probably more when I'm driving.
Would doing a drag link flip/track bracket tighten the steering up even tho I'm not in the 3" mark
