JudeinPa
I have been having a wandering problem with my JK since last November. It started right after installing a set of new Synergy HD ball joints.
it settled down a little but is still wandering. Measuring my caster with a angle finder noticed that my passenger side ball joint is 4.5 degrees and my driver side ball joint is about 5.5 degrees. I am starting to think that I need to adjust the driver side control arm to have it match up. When I installed the control arms I did measure and also checked that I turned them out the same amount of turns.
I do have all new unit bearings as well as heavy duty trackbar, drag bar and tie rod.
