Hey All,
So several months ago my Jeep went into limp mode while pulling up to an intersection. Can't remember all the codes that time, but they were all electrical related. I knew my battery was on its last day so I figured that was the issue and replaced (and tested as bad) the battery. All was well until recently. Now every couple of weeks I will throw a code or two. Again, they are always electrical something and they are general never the same one twice. Now this week I am getting codes every other day and multiple times a day sometimes. I was just trying to make it through the week so I can trouble shoot everything this weekend. Here are the some of the codes it has shown this week:
P0128 - Thermostat Rationality
P0344 - Camshaft Position Sensor Intermittent
P0652 - Sensor Reference Voltage 2 Circuit Low
P1628 - Sensor Reference Voltage 2 Circuit Erratic
P2127 - Accelerator Pedal Position Sensor Circuit Low
I have also had some PCM code that I forgot to write down.
I know just enough about electronics to burn something down. That being said, I doubt that the sensors are bad or that any one of those codes is actually the issue. My thought is there is either something wrong with the PCM or a ground or alternator or something that is causing an overall electric cluster fuck. My first step tomorrow will be to start tracing wires and be sure nothing is loose or damaged. Anything else I should definitely look at, or try? Please don't assume anything is too obvious, as I know next to nothing about electronics.
Thank you!!!
Thank you!!!
