Limpinlobster
I went out to cleghorn yesterday and did a little off roading. I Put it in 4wd so I could disconnect the sway bar for a smoother ride. I know the Sway bar connects itself if you go above 15 or 20 and will automatically disconnect itself once you slow down again. I was hitting a few areas a little fast and now the swaybar won't disengage anymore :doh: Plus, the sway bar light has been constantly blinking and I've tried turning the jeep off, holding down the switch, switching in and out of 4wd, and even trying to flex the suspension a little bit. I'm going to try to open it up when I get some time, but just wondering if anyone could point me in the right direction or give me some advice on what to look for. It's still under warranty so I was thinking about taking it in because the check engine light is on to. I just don't want to tell my dealership the whole story then deny me because I was off road or what ever. I'm already considering the EVO sway bar disconnect thing to. Any advice would be greatly appreciated.
