Primo82
Hello all.
I've got a 2017 jeep jku sahara. Never liked the rake and with a winch on the front its much worse.
I'm curious what everyones thoughts are on the teraflex body lift and leveling kits. They worth it? Should i get it with the shocks or the just the cheaper kit with the spacers?
When the stock tires wear I plan on moving up to 35s and once those wear (and if i can make the necessary/significant mods) I'd like to move up to 37s. Can these kits be used in conjunction with a more proper lift kit, say maybe a 3" with all the bells and whistles, to give me enough clearance to run the bigger wheels?
Can i piece together a premium 3" lift setup over time or is it better getting that all at once? What parts/phases would you do to step up to the 37s?
I plan on adding the Metalcloak Overline flares and trim which should help with clearance. Supposedly they will allow 37s to clear on a stuck setup. But i want the additional clearance also.
My ride is a daily driver. I'm close to redbird sra and plan on wheeling there. As well as traveling to some other trails. It will be dual use.
Cheers all thanks in advance!
