Hello, my name is Jose and I have a 99 wrangler with the 2.5l engine with the standard trans. My tensioner pulley is not spinning and is running through serpentine belts like water(3 so far in 2 weeks). I have since replaced the pulley itself and that has not helped. My question is.. is there a spacer that goes behind the pulley itself so that it’s not stuck on the mounting plate and able to spin freely. Currently, the pulley grinds on the mounting plate because I assume there is no spacer to separate the two components. This is my girlfriends daily driver and I can’t find anywhere online where people have had the same issue. Any knowledge is appreciated! Thank you!
Ps. The tensioner is the bolt style tensioner, not your typical 1/4” drive rotation tensioner. The tensioner assembly works fine and seems to do its job, my issue is that the tensioner pulley has been grinding on the mounting plate.
