TCase Front Output shaft Leaking
Saharacon
Like the title says, I noticed after wheeling this past weekend. My front transfer case seems to be leaking from the out shaft.
I have an adams 1310 DS and when installed had 4.5° total. I'm going to have to find my angle finder and go back under to be sure. I dont have ant vibes to say. More like a low frequency whooom whooom that I "thought" was tires
My question are as follows
1) is this most likely due to improper Driveshaft / Pinon angle?
2) am I looking at critical failure in the near future, and should I be pulling the tcase apart to replace seal
3) I do a lot of mudding is it possible the seal was just torn up from grime?
Going to clean the puppy up and see what it takes to replace the seal. I can't find anything on the Web about it or even a part number for the seal
