Noble Woodsman
I may be going down a rabbit hole here, but I'm having trouble understanding the backspacing recommendation from Synergy for their stage 4 long arm kit (3" or 4/4.5"), and I am hoping someone running this suspension can help me visualize this.
Synergy recommends a maximum backspacing of 4.75" with these LA kits to run 37x12.50R17 tires. I reached out to them to ask about this number, and and was told "our recommended backspacing is to clear the longer rear sway bar links and high steer drag link". Best I can tell from reviewing install videos, pictures, and the installation manuals, the rear sway bar links and high steer drag link/bracket seem to be the same dimensions as those found on the AEV DualSport 4.5" lift, which recommends up to 5.2" backspacing for the same tires. Would someone with the Synergy LA kit please post a picture of your setup showing the clearance between (1) the tires and rear sway bar links and (2) the tires and high steer drag link to help me understand what I'm overlooking? Please note what tire size and backspacing you're running for reference.
Ideally, I'd like to run a BS of 5.2" (or anything larger than 4.75") with the Synergy LA kit to help reduce strain on the stock axle wheel bearings, and I want to see proof that it won't work before I completely rule this out. Thank you!
