Synergy Jk Drag Link Question
LAJK
When running a 4" lift with 37's on a JKU, Is there truly a need for a drag link flip kit or would just a new drag link be fine?
If you don't want to flip it, unless yours is worn out just run the stock one, if it needs replaced I just found out here the other day the Synergy one goes either way so you can flip it later with a bushing drilled into the knuckle. Just make sure you raise the track bar and install 3" bump stops when you flip it.
I'm installing the synergy kit Saturday morning to go with my 4 in lift but for bump steer issues. I'll post any difference it makes.
