Synergy hi mount stabilizer
jman_12
Been looking at the Synergy hi mount steering stabilizer relocation kit. Is this the same as a drag link flip or not? I'm slightly confused...
I think it just moves your steering stabilizer to a safer spot. Probably need around 2" of bump stops to run one.
^^ you are correct I have the synergy stabilizer mount and if you don't have around 2-2.5" of bumpstop it will contact the frame
It's not hard at all. It's a lil easier with a buddy to help move the steering wheel back and forth to get the track bar bolt in and out and to get the axle side stabilizer bolt out but very doable alone. It's pretty straight forward.
Evo already has a hole for relocation. No need to buy this if using the evo mount.
I've seen that hole, my only worry is that my buddy had the steering stabilizer in that hole and the bump steer has bent his track bar bracket after about a year's worth of use. I saw somebody else on here having the same problem a few months ago too.
I think that one bent because the ss wasn't adjusted properly. No way a properly set up ss could bend a track bar mount.
Also, for the price the rough country isn't bad. 20 bucks or so. Hard for them to screw that up. I ran one for a while and had no problems.
