thebandit007
Hello. I have a 2018 TH and just received a Switch-Pro SP9100 switch panel. It is similar to a SPOD. I need to locate a light input (parking light or side marker wire), an ignition or ignition accessory input/wire , and a high beam, reverse light, or dome light signal/wire. Can anyone assist me with locating the ignition or ignition accessory wire and where to locate the high beam or reverse light wires? I have a led light bar on the roof, 2 light pods at the rear license plate bracket, and rock lights to install and connect to the Switch-Pro panel. I am OK when it comes to some installing add ons.
I was quoted 1100.00 to have everything installed and really dont want to spend that much. Thank you for your time.
