sipafz
I’m getting close to finishing the installation of my homemade budget boost kit. The front spacers are 2 1/2” and the rears are 1” tall. Net lift ended up to be the height of the spacers plus a 1/4” in both the front and rear. I have a winch mounted inside my stock front bumper that added 80lbs to the front and the Jeep is sitting pretty level. I’m real happy with the stance and ride.
My question is about the sway bar angles. Rough measurements show that the front sway bar is pulled down about 2” from level and the rear is down 1 1/4”.
Question #1 - Should I increase the length of the links to make the sway bars level?
I tested the strength of the link and found that they are made from mild steel. I’m thinking that I could simply remove them, cut them in half, thread each cut end and screw them into an extension nut to make them the length I need and lock it with a jam nut.
Question #2 - Has anyone ever attempted this?
This is what the extension nut would look like:
