Sway bar hard to move
Tranquillity
Hey, I'd like to know if it's a common problem for those with quick disco. My sway bar became very hard to move, any of you grease it or something ?
Should take a bit of pressure to move it out of the way if you are disconnected. They do make aftermarket brackets that have zerk fittings so you can grease them.
Is it just a pain to disconnect and zip tie the links up out of the way?
I have the reraflex quick disco, I need to move my swaybar upward so my link get into position. Last year the sway bar was easy to rotate but this year it is a real pain... it seems jammed or something
Your front sway bar is just held in place with rubber bushings and metal clamps. Could be the rubber has just swelled from heat. Really, it's not that big of a deal.
Yeah I checked it out and it seems to be that. Thanks :beer:
Have you tried blasting them with spray lube? That might loosen it up.
Nah, I wasn't sure if I should. Searched google and haven't found anything about that. I guess that's what I'll do !
