Could anyone explain to me simply what the advantage of having the sway bar disconnected gives during off roading? I hope it's ok that I ask some pretty simple questions here on the boards. I could google it but I do enjoy engaging in conversation much more
kaptkrappy said:The sway bars job is to keep the body of the vehicle from trying to roll over or "sway" outward when turning. It also acts as a travel limiter when one wheel is higher or lower than the other by keeping the axle parallel with the body. This is not good when you are climbing obstacles and trying to maintain maximum traction (all 4 wheels on the ground). Disconnecting the front sway bar while off road, lets the axle pivot much further than possible when its connected (see photo).
<img src="http://wayalife.com/attachment.php?attachmentid=2433"/>
Thanks! That makes perfect sense! I believe I read that one could manually disconnect the sway bar if you don't have an electric disconnect. How hard is this to do? And is upgrading to an electric disconnect a common upgrade? If so how costly is that?
Oh so this feature isn't even available for aftermarket on a vehicle besides a Rubicon??
