RSQCON
Not wanting to derail a certain thread anymore I came across this...
...and so I figured now is as good a time as any to ask. I am not a fan boy of any particular brand had have no allegiance. My Jeep is on order so I am in the 'serious research' phase and am of the mindset that I only want to do it once.
If you have 2 JKs running identical control arms setups, 1 with coil overs and the other with coil springs and shocks, will either setup achieve more flex than the other and if so why? I've seen in mentioned that with a traditional coil spring and shock the shock is what limits your travel so in theory if the shock has the correct amount of upward and downward travel wouldn't you be able to achieve as much flex as a coil over setup?
...How the hell is a standard style coil and shock going to perform better than a coilover system????
