rogerk93
I recently did the rebel extreme coil over conversion and have a issue I can’t figure out. After the conversion I flexed out my Jeep a few times but noticed that I am not able to stuff my wheel as much as before About 3 inches difference, and my down travel is kind of upsetting. There is a lot more shock that can be used for both up and down travel but it binds somewhere preventing it from fully flexing. I am thinking the way the tabs on the axle is placed and the tabs on the cage that is causing it to bind. If I rotated the axle tube tabs where it is parallel to the axle it will allow the coil overs to sway a little to allow more flex. I took some pictures to show how the tabs are welded up.
