ScoobyCarolanNC
I’ve paid to have my brakes flushed twice in a year and both times it was done poorly. I might as well took up and do it myself. Any recommendations on the kit I should buy?
And don't let the reservoir empty out!All you need is some clear tubing, a water bottle and a spring clamp... fill the water bottle with a couple inches of brake fluid..... drill a hole for the tubing in the cap... and a tiny hole for pressure release... submerge the hose in the fluid, and clamp the other end to the bleed fitting... loosen the fitting and pump break slowly. Because the line is submerged it won’t suck air back into the line... start with farthest first and work to the closest (tighten the fitting before moving on)... a couple rotations and you should be good... (I tape the bottle to something heavy so it doesn’t move around) ... or just get a buddy and forget all that shit. Lol
