Hi Whats up everyone? Hope you and yours are all good and well during this plandemic. I have some serious issue with my 2008 Jk Rubicon 2-door and really need some advice or help if you could. I have upgraded the entire front steering of my Jeep and can not get this thing to stay the course no matter what i do. I have brand new 4.5" metal cloak dual rate coils, teraflex ball joints, metal cloak tie-rod, metal cloak drag link, new Fox shocks, new extended brake lines and new sway links, newish 35" tires with plenty of even wear and correct air pressure. I have a new power steering pump and i am currently on my second remanufactured power steering pump from Autozone and this is where i believe the problem is still happening. Everything was great after i installed my new lift and then i noticed some power steering fluid leaking from the sector shaft so i replaced the steering gear box.Now i have replaced it again in 3 weeks because i thought it was a bad steering box except my Jeep still will not drive right. I swear i have had a lot of issues but his one is killing me. This Jeep just gets stuck in whatever direction it wants. I am all over the freakin road it's crazy. And then some bumps are fine but then all the sudden a certain bump will throw me all over and i can turn my wheel almost all the way back the opposite way before anything even starts to happen,while kind of babying it because if i over steer I will have to turn back against the way i am trying to turn in the first place. I probably should not even be driving my Jeep at this point. So really I only have a 1 major question.
Do i just go get a PSC Big Bore and hope this fixes this steering issue forever? What do yo think the problem is? I am convinced i still have a bad steering gear box but if i shell out 1k for a freakin steering gear box i would really like to know this will be my permanent fix for this current problem. Any help is more than appreciated. I can not even explain how frustrated i am now. I should be packing for camping but i am not taking this down the freeway at this point. Please help and have a kick ass Memorial Day
