WLFMOON
Hi Guys & Gals,
Haven't posted in a while.....Been super busy with my business.
Anyways, I have a strange situation with my 13' 2Dr Rubi.
Brief history: I have a MetalCloak 3.5" lift which I have been running for about 3 years. All front end parts drag link, tie rod, etc are MetalCloak. 35" tires on stock Dana 44 axles with 4:10 gears. Jeep has 42,000 miles.
Around 40,000 miles I noticed a slight shake in the steering wheel, and I knew that the stock ball joints were probably toast. Did a ball joint swap with heavy duty aftermarket ones.
Test drove. Still have the shake, so I thought perhaps the tires got worn funny. I tried my other set of 35" tires from my daily driver....shake still there. Went the route of changing out the bearing/hub assembly's.
Also checked every component for proper tightness in the front end. I can't find anything wrong.
I still have a shake in the steering wheel from about 40mph to 60mph.
Would like to hear your opinions of what you may think it is.......I'm at a loss at this point.
