So here’s the deal, as short as I can. One day, Jeep runs perfect. Next morning, start it up and my dash looks like Christmas. The ETC, Traction Control, Check Engine and TPMS lights, all on. TPMS, easy fix. FYI - this is 2012 Jeep Wrangler JKU AUTO, w/ 84,000 miles, 2 1/2 lift, on 35x12.5x20 Maxxis Bighorn mud tires. (Quick shout out to Maxxis. I literally have put ALL 84,000 miles on these tires, and they still have enough tread left to pass inspection! WTH!!). Back to the issue. In my research, I’ve heard horror stories of other Jeep’s with this issue having to limp home, Jeeps just stalling out, running bad, etc. And then, hearing about multiple trips and LOTS of dollars thrown at it, and still not fix the issue. But here’s the thing. The Jeep, basically runs perfect. No hesitation, no spitting and sputtering, no stalls. Will easily maintain 30mph, or 75mph on the highway for as far as 100 miles so far. The ONLY issues I have found to date are, (1) one - it will not go into Cruise Control, (2) two - it will not shift to 5th on its own. So if I’m going down the highway in 4th, I can manually downshift and then manually upshift to 5th, and that works. (3) three - when trying to accelerate to pass, it will not kick down a gear for more rpms to pass someone. Again, I can do it manually, but not on its own like it should. Otherwise, shifts up and down like it should on auto, and no other noticeable concerns. Even MPG is the same. Like I said, I cannot afford to throw money at it, hoping something works. FYI -New oil change, new gas, injector cleaner, etc, as preemptive strikes. Also it does show - P520, P300 codes. I do know the P300 is a misfire code. However common sense would say if it were a misfire, it wouldn’t be running smoothly. Does anyone out there have any thoughts, ideas, heard of this, “like” this, solutions, etc. ??? I would really appreciate some advice and/or direction. Thanks.
P.s. Someone suggested a battery issue. All cables and post tight and clean. 1 year old Optima battery. Already tried computer reset with no luck.
