Stock trackbar adjustment on JKU?
Hey team I was watching this video on the Teraflex adjustable trackbar adjustment and was wondering if i can perform something similar to this at home on my 2012 JKU???
http://youtu.be/3qVhY17xmpw
My axle isn't quite centered as in the Jeep on the video.
You can with an adjustable track bar. The TF track bar allows you to adjust it without disconnecting the track bar...if you are using the stock track bar the only way to center the axle is with a track bar relocation bracket. If you take that route you should re-enforce/weld the bracket. If not a lot of times the bracket puts undue stress/leverage being bolted onto the stock bracket which causes it to break apart from the axle.
I see that you are running a TeraFlex 3" lift and if that is true, you more than likely have more than 4" of lift. At that height, you really want to install a drag link flip/front track bar relocation bracket instead of just an adjustable track bar. Having your axle off center isn't that big of a problem but with your steering geometry being as off as it is now, you will benefit with improved handling if you correct it. I do need to stress that it is critical that you address BOTH your track bar and drag link at the same time. Failure to do so will result in poor handling. I would highly recommend the EVO kit as seen below:
http://www.offroadevolution.com/store/proddetail.php?prod=EVO-DRAGLINKFLIP
Very good info! Thanks guys!
And yes my lift is a lot taller than anticipated. Probably should have read up on TF lifts a little more before purchase.... next time.
