C gussets, lca skids and maybe chromoly axle shafts with full circle clips up front is about all I would do.
Thanks guys, I think it was the full circle clips that I read in an article that Eddie posted and seem to remember that improvement being simple but critical. Pardon my newbie lack of knowledge but what are Ica skids?
A good differential cover would also be useful. This Solid cover only cost me $65 and even shows up with a big tube of RTV.
...chromoly axle shafts with full circle clips up front is about all I would do.
I wouldn't waste my money on a diff cover unless I bent my stock one like 10frank9 and Hinrich did. If so then replace it or look for a stock one in good shape off of craigslist for cheap .02
The stock covers are pretty solid, the only issue I've seen is the thinner "lip" peeling if drug across rocks. Most aftermarket covers have more rounding to them. I saw this personally happen on my dads Rubi which led to a slight drip.
Sent from my Nexus 10 using WAYALIFE mobile app
you can easily get around this by grinding the lip of the stock covers down so they don't get caught on anything and bend
What he said. In addition to gussets, chromoly axle shafts with full circle clips are about all that I would invest in and ONLY after the factory shafts were shot. Hell, I'm still only running one chromoly front shaft on Rubicat :crazyeyes:
Aside from that, I would just save up for a ProRock 44.
Hi Wayalife!
Are you guys still running D44s on rubicat? I saw that you upgraded the suspension but hadn't seen whether or not you were still using the stock 44s or went with 60s?
rubicat is now running a PR44 front and the old PR60 that was in moby.
Ok. Thanks! So just trying to be clear; he's saying that the prorock 44 still has a factory shaft in it?
Sorry if I'm being a bit slow LOL
