My jeep steering wheel tend to go left turn while driving.
Alignment is center.
Does anyone know reason?
Could be the crown on the roads you drive. Roads are typically higher in the center to aid in the drainage of storm water.
Sent from some trail, somewhere
What kind of tires are you running? What kind of steering stabilizer are you running?
This might be true if the pull were to the right but, his is to the left.
Just clarifying, when you say alignment is center - are you talking about your tire alignment or you've already aligned your tires and steering wheel to be true to each other? tires straight, steering wheel centered when stationary
34" nitto trail grappler with stock stablizer.
What you are experiencing is totally normal for those tires. Some people refer to it as radial pull.
Thanks
By the way, i just dropped my rig to re-gear at EVO, and i think i saw moby at the shop.
Good choice. What gear ratio did you go with?
FYI....my rig does the same thing. Slight pull left when my hands are off the wheel. My rig is aligned properly and I'm running NITTO'S
I'm going to 4.56.
35's? And what year?
