Probably dented your steering stabilizer??
05 Tj, long arm, one ton, lockers, winches, 39.5" Iroks
X2 same thing happened to a guy I recently wheeled with.
Is it pretty easy to fix?
Remove it and see if your steering is back to normal. If so you can drive without a steering stabilizer or order a replacement.
I was thinking if I replace. It's prolly worth it to get a pcs pump
That video doesn't show where the dent would be... But you can tell that it's binding up .. Did you try removing it yet?
Hey man thanks guys for your help.
I removed and it drives like a charm. It will do for now haha
Also, most of the guys on here recommend replacing it with a stock steering stabilizer... Some aftermarket ones can cause your jeep to pull to one side, While the stock one is just right.
