I recently added a body lift to my JK which I had to add the spacer into the steering shaft. When I first installed it everything was good. Went back a few thousand miles later to check everything and found it was loose, I removed it checked splines etc to make sure nothing was worn. I reassembled and used blue locktight on the setscrew and bolts to combat the before problem. Fired the jeep up and boom..Christmas tree in the dash. Both the Stability light and the ESP/BAS light are on. Steering wheel is centered still, no changed was done to the alighment. I reset the codes with my superchips and fired it up again..the lights came back. I checked the codes and one said erractic steering agle and the I foget the other, both had to do with steering. I have cleared them and drove the jeep and no change. It doesn't throw the ABS light on as well like it would if a speed sensor is bad or failing. Cruise and all still works. I think the steering wheel may have turned once or twice a revolution or whatever while it was disconnected. Would that have caused this? Could it have broken the clockspring?
