I need some help. It's my first post here. I have an '87 yj I'm restoring. It does need a lot of work and I'm kind of learning as I go. I've had some experience at this, but I'm a novice. I did change out the mechanical fuel pump because it wasn't getting gas. It still wouldn't start. Then I changed out the stock carb to a Weber. Now it gets gas and starts up but will only stay on if I'm on the throttle. If I let off, it bogs down and stalls with smoke coming from the air cleaner. Any suggestions, other than the timing, on what I should look for next? Thanks
Sent from my SM-G955U using WAYALIFE mobile app
