I took my muffler off cleaned it with brake clean then used this
http://m.homedepot.com/p/Rust-Oleum...amel-Flat-Black-Spray-Paint-248903/202623076/
I also fluid filmed the area while the muffler was off.
I can't figure out how to get it off..![]()
The exhaust is a PITA to get off. WD40, elbow grease, and a whole lot of patience are really the only requirments.
Where are the bolts that need to come off? Does someone know of a diy thread?
Here are a few better photos I just took of my buddy's stock exhaust. They show the 2 hangers you'll have to remove and the clamp you'll have to loosen to separate the pipes. The clamp can be removed with your average socket set.
Clamp:
Driver's side hanger:
Passenger's side hanger:
Once you've done all that you'll need a flat head screwdriver and a hammer or mallet to separate the two pipes.
Gotcha. Are he hangers just bolted on as well?
Nope, they attach through rubber grommets that aren't bolted.
Do they just slide through or slide off?
You will want to slide the metal hanger welded to the exhaust through the rubber potion. As already mentioned it is a true PITA to remove the muffler from the rubber pieces. You can use WD-40, PB blaster, or white lithium grease to lubricate the hanger. If you have a set of vice grips you can use those to squeeze the metal hanger through the rubber portion.
Yeah, it sucks, to say the least.
Ive seen some people posting that they used high heat black spray paint on their exhaust to match the underside of their Jeep. Ive heard of Rustoleum having a good product but are any others better? If someone has done this, was your Jeep lifted off the ground?
