I purchased a Spectre SPT 8138 filter on Thursday, November 16, 2017 and installed it the same day in my GMC LS V8 equipped 2010 Jeep Rubicon. Three days later, on Sunday, November 19, 2017, in Death Valley, the chrome end cap came loose and was sucked into the throttle body assembly, causing the engine’s ECM to immediately shut down the engine. This occurred while I was driving.
Several members of the caravan I was a part of stopped to assist me. One of the other drivers, based upon the DTC codes displayed by my ODB II scanner, suggested removing the air intake tube that sits between the filter and the throttle body. Upon removing the air inlet tube, exposing the throttle body assembly, we discovered the loose cap sitting in front of the butterfly valve, preventing its normal operation.
Had this chrome cap been sucked past the butterfly valve into the engine, it could have caused a lot of damage. Even if it didn't cause damage, it would have been a lot of effort to retrieve it.
This is the worst conceivable design. There is nothing holding that cap to the inside of the filter. There is no evidence of the cap ever being crimped, glued or otherwise permanently attached to the inside of the filter. This cap should have been designed to fit on the outside of the filter, so that it could never be sucked into a running engine.
