JEEPnGEO
I have NEVER seen in any detail a BONE STOCK front end of a 09 Rubicon I know that they all should be the same so if that is true I still haven't seen a BONE STOCK JK Rubicon front end.
I bought my Jeep and someone already did some work to it so I want to pick up where they left off. Except I don't know what they left off or on.:bleh:
Here is a whole slew of pictures with notes as to what and why and can I.... These pictures were taken after I installed the TeraFlex springs I bought off of RK Racing. The jeep was running a 2.5 inch TeraFlex Budget boost with 9550 TF shocks.
Who ever put on the budget boost I still have the drop breakline adaptors, shocks, swaybar ends, that they put on. If you look up my other post to RK Racing you will see the height difference between the two. Since I did the spring swap and gained 2 more inches so nor I am about 4.5 inches above stock (I believe) I need to make up the delta. Longer track bar, upper lower CAs, I would like to have stiffer sway bar links if that would make the difference.
Can ya-all tell me what I need (in order) so I can buy a little at a time and swap parts out. I defiantly need break lines sooner than later. I can't go jeepin again with out them. Almost no play. After that I would like to source an adjustable track bar. I will someday upgrade to 37's and go no bigger. I want this to fit in my garage. 37's and this lift will be my limit.
Thanks in advance and PLEASE HELP.
