Spacer lift
Kromar
Hoping to put a 1.75 spacer lift on my 08 Rubicon , that's if I measure correctly and it fits in my garage. Do I need to do anything with the electric sway bar discos. ? Thanks in advance
You'll want to run longer sway bar links in the rear and then you can install your factory rear links up front. This will help compensate for your lift and will help prevent over extending your links and damaging them. You'll also want to install rear brake line drop brackets and bump stop extensions to help prevent the over compression of your coils. Shock extensions would be helpful to have as well as a rear track bar relocation bracket too.
