LoD are also weld on...if you should choose to do so
Are those frame mount, or body bracket mounted? Many companies claim "frame mount" but they use the tub/body mount.
LOD(weld on or bolt on)
Great info StrizzyChris
The Hyline ones are like your first pic...Bolt on to the frame. Had to actuall drill 6 holes in to frame of jeep on EACH side and then run a U-Bolt through and connect that way. Kind of a pain. In one spot i had to actually drill up and then tap the hole to thread it. It was a true labor of love but glad i was able to do it myself.:thankyou:
