clarsen said:Has anyone had or found rusting issues from armor bottling directly to the body panels of your rig?
Thx Eddie that's what I thought!wayoflife said:living in socal, things like rust really is a non-issue. but, for you, i would probably recommend that you apply a bead of silicon along the edges of the armor to keep bad stuff from getting in between it and the body.
Same same Greg thx, I wish brother I wishGCM 2 said:Chris like Eddie has mentioned, all it's takes is just a little more diligence in your prep work of the sheet metal and armor surfaces. Anything that has been drilled needs a little primer and paint before you start bolting those surfaces back together.....or you could just store your JK down here with us where rust is a non factor :rock:
Chris you are so negativeChrisB said:Coming from the eastcoast. No way would I put anything like that on in Canada.
Glad I don't have to worry now![]()
Thx that's what I like to here!Indefatigable said:I have had PSC full corners on my LJ for almost 4 years. Just took them off to weld on flares.
I had a bead of silicone along the top of all the plate to keep junk from falling into there. Nothing on the bottom side though.
Only rust was on the holes I drilled or chipped when putting in the bolts. And of course where road debris chipped the paint away on the underside.
Otherwise, really no rust. I was expecting alot and have very little clean up to do before I put the armour back on.
But, I live just outside of Vancouver, BC. Its not like it rains here much and I never have had covered parking. It was always out in the elements. Daily driver up until a few months ago.
Chris you are so negativebut you honestly don't think I could prep it well enough with silicon and TLC?
I dont think so, its the constant chafing of the paint between panels. Eventually it will give you problems.
