scull20
I've got a set of Evo ProTek Skids on my '14 JKUR. The bolt that goes into the frame on the far passenger side to secure the skid was endlessly spinning today when I went to drop the skid off the Jeep (the rest of the bolts came out fine).
I ended up having to cut the bolt off with a cutting disk and angle grinder in order to remove the skid. It seems like the "nutsert" that was secured to the inside of the frame broke free. Now I've just got an oblong in the underside of the frame and no threads to fasten the skid/bolt to anymore.
I'm gathering that there is no "quick and dirty" solution to this problem. Does anyone know of a large "nutsert" that I could utilize in this location...or any other non-welding solution?
Otherwise I'd imagine I'll have to have a nut tacked into place here. Or perhaps say a piece of plate with a hole in it with a nut already welded to one side with the hole lined up. Then just tack the plate to the frame on the outside and the welded nut will be inside the frame. The mounting hole will just be dropped slightly by the thickness of the plate. Perhaps I'm overthinking it? I'm open to suggestions.
