neZZr
Just thought I would share a slick option for adding electrical circuits inside your jeep. Especially good when you're as anal about keeping things factory looking as I am.
First I installed a nifty fuse block from Fuzeblocks.com. It's designed for motorcycles, but works perfectly here too. It only handles 10A per circuit / 30A total, but if you need more than that you probably already know better ways to accomplish this. I still like the compact package, and it works great for my needs.
It has six circuits, each of which can be constant or ignition switched just by moving the fuse for that circuit. I made a simple aluminum bracket to hold it in relatively easy reach behind he glovebox. Right now it's supplying my heated seats, and soon I'll hardwire a phone charger. Eventually I'll power the CB from here as well.
I ran 12awg straight to the battery with an inline fuse, and because of where I installed it, the wiring is very short. Of course you can also see the sPod wiring as well. It all tucks in nicely out of the way with a factory appearance. It's not even in the way of replacing the battery! I tapped the factory power outlet for the ignition triggering.
Any questions I'd be happy to answer. Just thought I would share this cool setup I used as I hadn't seen anyone use this in a jeep before.
