Silly Newbie Question
gheller
I've got Willys Wheeler JKU WITH 33's and a 2" budget boost. If I'm going to head out to some trails, easy to moderate, what would be the mod I need most. I'm thinking some sway bar quick disconnects at the least. If so, what do you recommend? (Ive got a manual with 3:73 gears)
Sent from Earth to Space and back...can ya give it a second!? WAYALIFE mobile app
Swaybar quick discos are good. Also an oil pan skid is recommended as well. Otherwise if your out with people they should have a winch a tow straps incase you or someone else gets hung up. Most importantly just go and have fun
Well said. Ditto on skids and recovery gear.
Thanks, man. I figured a winch is not a necessity since I would be going with a group but I do plan on getting one soon, a Warn. I already have the Trail Rated Recovery kit which includes a Warn tow strap, shackles and gloves.
Concerning Sway bar discos, what's recommended?
I've seen the JKS mentions a lot.
What about oil pan skid?
Jks quick discos are prob the best. If you plan on lifting higher in the future just got the 2.5-6" lift ones.
For oil pan I like the evo and rancho skid. I ran the rancho one for years and only got rid of it for the evo cause I installed there whole protek system
Thanks, good info. Being that Rancho is a supporting vendor I'll look at those first.
