sarneli
Hi all,
So I have the 6 speed, and had the clutch replaced at the stealership in August.
2020 JTR with 105000KM (~65000 miles).
About 9 days ago, the throwout bearing decided to seize and give up the ghost. I didn't bother with going back for the service/warranty, since I knew I would be swapping to a centerforce clutch. So, that pooched bearing forced my hand, and I did it with my dad last week. Cool. It is driving now. But today, I got a 'service transmission' message on the dash screen. No actual DTC/MIL codes. It remained on for a few ignition cycles and some driving around the city/freeways. Then on my last ignition cycle, there was no mention of it anywhere. It doesn't make any noises, no vibrations, etc.
Three-ish months ago I did all the fluids with the manual's recommended stuff - Transmission, t-case, front and rear diffs. No leaks, everything has been smooth.
So aside from the obvious (probably a bad sensor or wiring connection, which I will investigate shortly tonight) - what other problems will trip that error message?
