I pulled on the belt and had good tension. Runs idle just fine but when I drive it then it pops off after about 5 minutesPull on the belt itself. Is there good spring tension? Maybe the idler?
Sent from my SM-N920T using Tapatalk
I played with the Pulleys and they all seem tight. The bolts are all tight also.Check for play in the pulleys by rocking them. I bet one of them is loose.
Here is what I observed. The belt looks like it comes in at an angle to the tensioner from the crankshaft. When I crank it, the tensioner moves backwards then forwards and the belt pops off the crankshaft pulley.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Yea it's the old belt and I can only think it was hitting something due to the misalignment. I have tried two new belts and the old belt and get the same results. I pulled the tensioner off and one of the bearings was busted and leaking grease. Not sure if that would cause the misalignment or anything else.Being that it's shredded on the outboard side, make sure it's not rubbing on something, like a bolt, hose, sharp edge on pulley, etc. I realize that may have occurred when it came off as well, but seems strange that the entire circumference is fraying.
Here is a shot from the crankshaft to the tensioner View attachment 299512
tensioner was bad? i was thinking it was good.Yea it's the old belt and I can only think it was hitting something due to the misalignment. I have tried two new belts and the old belt and get the same results. I pulled the tensioner off and one of the bearings was busted and leaking grease. Not sure if that would cause the misalignment or anything else.
I'm hoping that all it is. I'm changing it out tomorrow and we'll see.tensioner was bad? i was thinking it was good.
a bad tensioner would allow the belt to flop off.
may be what frayed the belt edge as well
Welp got my tensioner replaced and new belt on and lo and behold. More squeaking and a loud clank. Found this big guy lying on the floor. Crankshaft pulley. I'm assuming I won't have the tools to replace this one. View attachment 299780
Yep motor turns fine. I've never seen anything like this. Looks like I'll take a trip to the auto store tomorrow and see what I can do first. I can only imagine how hard it's going to be to get that bolt out. I only have a corded 1/2 impactholy shit!
well, you could get the tools from your local auto parts store loaner tools.
motor still turns over ok? I've never seen one fall off like that, that's a shitty deal
